Simulating airflow in Thermal Simulation
markdagraca
markdagraca
Is their to simulate airflow in thermal simulation that would be equvilant to a Blower fan
Phil.E
There is not.
If you check the Blog for what's new, you can see there is only the following thermal loads available:
"To get more technical, Thermal Study allows you to analyze temperature distribution in the design caused by heat input and out. Load types include: Applied Temperature, Surface Heat, Radiation, Convection, and Internal Heat."
What's new blog post:
https://forums.autodesk.com/t5/design-differently/january-23-2016-update-is-available/ba-p/5998350
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
