Lower version upload not finishing
TrippyLighting
Consultant Consultant
TrippyLighting
I worked offline yesterday during the mainenace period.
When going online again, as expected, Fusion 360 started uploading the svaed versions. Vrsion 19 uploaded fine (I am now n V20),
but version 18 does not ever complete:
kris_berg
Hi @TrippyLighting,
Sorry to sound like a broken record, but can you send me (kris.berg@autodesk.com) your log files.  I will start investigating them when I receive them.
Thank you,
Kris Berg
Fusion 360 Development
Kris Berg
Senior Software Architect - Autodesk
TrippyLighting
Done!
kris_berg
Hi @TrippyLighting,
After looking at the logs and additional data, we believe it is just an issue with the UI and not an issue with the upload of the file.  To workaround the issue, make sure you do not have any active uploads (other than the falsely reported v18) and close Fusion 360.  Then in Finder go to:
/Users/<your user name>/Library/Application Support/Autodesk/production/JobManager360/<some random letters and numbers> and delete the files "jobs.json" and "jobs.json.lck".  You can then relaunch Fusion 360.  Let me know if this doesn't fix the issue or you need additional help.
Thank you,
Kris Berg
Kris Berg
TrippyLighting
Hi @kris_berg,
That fixed the problem. Thanks!
