I'm trying to simulate a cantilevered aluminum glass shelf bracket that mounts to a glass wall. Here's my model: http://a360.co/1Sd3Zky
The bracket consists of two aluminum discs with a connecting tube of aluminum between them. They sandwich the glass wall. An aluminum (or steel) rod goes through that, and the shelf will rest on the rod.
I want to make sure the torque introduced on the glass wall by the bracket doesn't break the glass there. So I set up the simulation and put a force on the end of the rod. The model I built is a bit simple, in that the disks, tube, and rod are all a single solid.
I run the simulation and see deflection in the rod (by the way, I couldn't figure out how to get a downward force centered over the end of the rod; it's actually off to one side), but I don't measure any stress/strain/contact pressure in the glass around the bracket. This leads me to believe I did something wrong in the modeling.
Can anyone help me out? Thanks!
