Simplify geometry for use in Simulation
lucasliraAU
lucasliraAU
Hello everyone!
Smiley Happy
I was starting Simulation: Fluid Flow in a tutorial created by Thom, during that lesson Thom uses a process that I can not follow the same path. Observe the figure below:
During this phase of the lesson Thom uses the simulation section and uses a feature called (Simply geometry for use in Simulation). When I'm on my Fusion 360 I can not find this feature available to proceed with the guidelines. My window is in this state:
What could I do to get around this case!
Thank you for your availability for this job!
Lucas Lira - Fusion 360 Technologies, Design and Applications - Autodesk Hub Diamond
Direct contact at: https://www.linkedin.com/in/lucaslirasantos/
VEX Robotics Engineering in Brazil - https://www.vexforum.com/u/lucas_lira/summary
Main Researcher and Technology Applications in Nerd Factory - https://www.fabricadenerdes.com/
TheCADWhisperer
I see it in your screenshot.
Different location than old screen.
lucasliraAU
Hello @TheCADWhisperer thanks for your availability!
Both environments are a simulation. What could be done to get into the environment that Thom is using to complete his simulation of simplification ...
TheCADWhisperer
What is the link to the Tutorial?
If you look at the icon to the right of the study icon, that is the simplify workspace.
Here's a video I made of a similar process. Jump to the 50 second mark for a quick answer.
https://youtu.be/KbIve0iQf1k
lucasliraAU
Hello @Anonymous
I watched your video and found the feature, it was under my eyes kkkk.
Thank you!
the video is unavailable
