- Mute
- Permalink
- Report
Hello everyone!
I was starting Simulation: Fluid Flow in a tutorial created by Thom, during that lesson Thom uses a process that I can not follow the same path. Observe the figure below:
During this phase of the lesson Thom uses the simulation section and uses a feature called (Simply geometry for use in Simulation). When I'm on my Fusion 360 I can not find this feature available to proceed with the guidelines. My window is in this state:
What could I do to get around this case!
Thank you for your availability for this job!
Lucas Lira - Fusion 360 Technologies, Design and Applications - Autodesk Hub Diamond
Direct contact at: https://www.linkedin.com/in/lucaslirasantos/
VEX Robotics Engineering in Brazil - https://www.vexforum.com/u/lucas_lira/summary
Main Researcher and Technology Applications in Nerd Factory - https://www.fabricadenerdes.com/
