Simple Split Body Question
jburickJUFQ4
Message 1 of 8
jburickJUFQ4
So, I have a student who is trying to split a body - he just wants to split the one side of the "U" but the splitting tool extends so that it splits both ends of the U - for the life of me I can't figure out how to just the one side.  I have been using an offset construction plane as the cutting tool and obviously it extended through the whole body even though it doesn't look like it would.  I have also tried using a sketch drawn on the construction plane as a cutting tool but that also didn't work.  I would imagine it is something really simple I'm missing?  Thanks in advance!
Replies (7)
Message 2 of 8
ritste20
Not a perfect solution, but you could press/pull one end back the distance required for the split, then extrude a new body from there "to object" and pick the other end of the bolt if you need that piece. If you don't need the body split and just want the tangent edge present, use a split face instead.
Steve Ritter
Manufacturing Engineer
AutoCAD/Draftsight
Inventor/Solidworks
Fusion 360
Message 3 of 8
TheCADWhisperer
Is the Design Intent to Split Body, or is it really to Split Face? In any case > Attach the *.sldprt file here.
Message 4 of 8
jburickJUFQ4
The idea is to split the body at that point so he could create a component out of each and then join them with a rotational joint.  He kinda did it backwards, but I was trying to see if we could do a quick split and then convert them to components.
Message 5 of 8
TheCADWhisperer
Sketch1 is not dimensioned?
Message 6 of 8
jburickJUFQ4
I did a quick circle just to see if I could split within the extents of that shape.  I went back in and dimensioned it but it wants to split along the x-axis.
Message 7 of 8
g-andresen
1. select sketch plane xy
2. split body
günther
Message 8 of 8
jburickJUFQ4
Aaaaaaaah thank you so much!
