Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Can someone show me how to center sketches between two points. If you look at the attached picture I'm trying to center the circle between the two lines marked by black arrows. Could someone do a quick screencast and show me how please?
I'm still very new at this
Solved by hamid.sh.. Go to Solution.
In sketch workspace use Project (or keyboard shortcut P), select those two lines; You will get two lines that you can use for referencing, e.g. by drawing a construction line between their midpoints and apply coincidence between its midpoint and circle's center. Like this:
By the way, I mentioned Project because I don't have auto project on in my Fusion's preferences. I you have it on (i.e. haven't changed the default) you can already snap construction line's ends to those midpoints.
Thanks for the information! I found about 50% of the solution myself and you gave me the other 50% So thanks my friend!
