Show Bulb selected but can't view sketch
jeffKNYVZ
jeffKNYVZ
After editing some earlier features, I can no longer view the last 2 of the 8 sketches in a model.  The light bulb is on, but the sketch doesn't show up.  If I go in to edit the sketch you still can not see it.  When I hover over the sketch in the tree, the outline shows.
Attached is a screen recording of the problem.  Any help is appreciated.
davebYYPCU
Try moving the timeline to the end, and turning the light bulb on the last Component, on.  See if that helps.
jeffKNYVZ
Dave, Thanks for the suggestion.  I tried that and I didn't seem to change anything. I appreciate the assistance.
jeffKNYVZ
I am still having this issues show up.  it seems to happen after I roll back and edit something earlier in the model.  It is quite frustrating.  Any help is greatly appreciated.  Thanks.
TheCADWhisperer
Something can't logically be shown before it exists in history?  (There were no pictures of you before your parents were born.)
With history based modeling you can move back and forth in time, but you have to follow the rules of navigating with a time machine.
Can you File>Export and then Attach your *.f3d file here?
