Show 3d dimensions (not in sketch)
If I import something, is there a simple command that will show all dimensions?
I looked at "08-28-2018 08:55 AM  Re: How do I add dimensions to 3d views of models  ", but it only does it with a sketch and not a whole object.
davebYYPCU
Fusion will not place a 3d dimension, in its own program, so imported data, is even less likely.
Might help....
Phil.E
@davebYYPCU is right, thanks.
If you wish to see a persistent dimension, create a sketch on the plane, place a dimension (which will be a driven dimension) across the points you wish to show. In the sketch palette, un-tick "show profile" and "show projected geometries". This will make a nice clean persistent dimension that updates with changes to the model.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
