Shortcut for operation that doesn't have the add shortcut option
Is there anyway I can add a shortcut for an operation that doesn't have the (3 dots)-add shortcut- option
I am not sure if this features available but I scavenged the shortcut list multiple times, youtube, website and the preferences as well and still didn't find anything
since my question is a bit vague I will give what I am trying to do:
1. I need a shortcut for the "Select through" option for the Selection Filter, basically by clicking it I enable it, and by clicking it again, it get disabled
2. their are many modifier that has this option but I will give the example on the "SPLIT BODY" modifier
As known these are the usual steps that done to split a body
1. select the body
2. click on the "Select" next to the -Split Tool-
3.then select the spliter face or line...
4. then hit "ok"  or "Enter"
What I want to do is to give a shortcut to switch between the selection option, so it be something like this:
1. select the body
2. click the Shortcut for example "TAB" and this will auto switch to the -Split Tool- selection
3.then select the split line  ....
and by pressing "TAB" again it can loop back
I know it is a bit of odd question/ request but been trying to do this for sometime but didn't get anywhere and thought maybe you guys can help
g-andresen
NO!
günther
mango.freund
please take a look in autohotkey -- but i'm not sure it will works in fusion.
https://www.youtube.com/results?search_query=autohotkey++
Thank you for the suggestion, this look interesting and it might help
there is also another solution that might work but not sure if it will do what I want exactly, which is creating a python script for it, but IDK
