Shortcut for Display Settings / Object Visibity Toggle on/off
howardkinkade
Message 1 of 8
howardkinkade
In my typical workflow I need to toggle Display Settings - Object Visibility on/off often to hide and show "all work features". This takes a few mouse clicks each time I want to do this, is there a keyboard shortcut to perform this selection for me?  Can I create one?  And my favorite solution would be this short cut mapped to my 3D Connexion Space Mouse.
Replies (7)
Message 2 of 8
johnsonshiue
Hi! I could be wrong but I don't think there is a dedicated command or toggle to make all work features invisible/visible. But you can easily click on the Construction folder and press 'V' to change all construction geometry visibility.
Many thanks!
Software Test Engineer
Message 3 of 8
howardkinkade
I'm not certain what / where the Construction folder is located.
Here's a shot of the menu selection I'm trying to find a way to easily toggle without the necessary mouse navigation and clicks.
Message 4 of 8
kacper.suchomski
Kacper Suchomski
Message 5 of 8
billbedford
The keyboard shortcut "V" will toggle on or off the visibility of any selected item in the browser.
Message 6 of 8
howardkinkade
Thanks for everyone's suggestions.  However, my goal is to toggle on/off all visible origins, planes, sketches. . . all at once.  Any way to do this?
Message 7 of 8
billbedford
If you use 'V' with one component selected everything visible within that component will be hidden, if you select the base component everything visible will be hidden.
Message 8 of 8
darrin_hiebert
Just curious if you ever found a way to do this?  I too would like to be able to do the same thing.
Thanks!
