shell toward to outer direction of complex 3D surfaces
skullmathLB534
Message 1 of 10
skullmathLB534
I have an 3D model like this.
I want to extend or shell this model in outer direction.
However, I am stuck in the process with errors.
Is there anyone can give any advices to me?
Thank you!
Replies (9)
Message 2 of 10
davebYYPCU
Original STL file Needs to be converted to quad mesh in Blender,
So that Fusion can convert it to a Tspine.
No point in converting the STL to a triangulated solid.
Might help....
Message 3 of 10
skullmathLB534
Thank you for your advice.
I will transform STL file to Quad meshes.
And in Tspline, can I shell or resize the model?
Thanks!
Message 4 of 10
wersy
Just for information in case you want to print it.
You do not need to shell a part to print it hollow.
Message 5 of 10
davebYYPCU
I think so, by how much?
Message 6 of 10
wersy
Is the scale correct?
The part is only 28 mm.
Message 7 of 10
laughingcreek
just my 2 cents, there are few times when converting a mesh to a solid b-rep is necessary or desirable.   Fusion isn't very good at dealing with these types of models.  what is the end goal here, there is likely a different workflow that will achieve the result you want w/o having to convert the mesh to a b-rep.
Message 8 of 10
skullmathLB534
it's really helpful to my model.
Thank you so much.
Message 9 of 10
skullmathLB534
yes it is quite small model.
Message 10 of 10
wersy
I ask again. Do you want to print the part?
There are bottlenecks of less than 0.4 mm.
