Shell Feature not working for complex object
So I am very new to Autodesk and I was trying to make a thin skin for a finger scan I have. When I tried to shell out the scan I just get error messages that say "Error: The body could not be repaired after deleting faces.
Try changing the selection, or use the Delete tool in the Patch workspace to delete geometry without repairing the gap." I am not sure how to fix this or if I have other options. What can I do to make this work?RH with Prosthesis v2 v1.png
TheCADWhisperer
@Anonymous wrote:
... What can I do to make this work?
I recommend not using planar faceted triangular stl in Fusion.
Model from scratch
or
try using Autodesk Mesh Mixer.
So I should use mesh mixer to convert the triangular mesh to some other kind of mesh and the shell feature will work?
TheCADWhisperer
Attempt to do the Shell in MeshMixer.
