Shell Casing
Shell Casing
Shell Casing
How does one cut out a part from the shell? I've created a shell casing and in order to get rid of inteferences from other bodies protruding out, I need to cut out a hole from the casing to allow it to be accessed from the outside. Any tips?
michallach81
Would be helpful if you could post some images, but in general try to use combine tool (cut option in dialog window)
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
That works! Which brings me to ask... What if I want to make some spacing from the opening? As it is of now, it fits exactly.Untitled v7 v1 v1 v1.png
michallach81
Pick faces that were created after combine cut, and hit Q on keyboard. This is Push/Pull command, very universal one, in this example it should offset faces. Remember that you need to pick faces first before enabling Push/Pull command, if you will first run command you need to pick faces while holding Ctrl (on Windows).
Michał Lach
Designer
co-author
Thanks! This will help me greatly! Cheers~
