Sheetmetal Pyramid
Sheetmetal Pyramid
Message 1 of 8
Sheetmetal Pyramid
Hi. Has anyone been able to create a one piece flat blank in sheetmetal of a pyramid without a base as I can add one bend but when I add the second bend, my Fusion keeps crashing.
Replies (7)
Message 2 of 8
TheCADWhisperer
Do you want the Rip at a corner or do you want it mid-panel?
Message 3 of 8
Joint at one corner.
Message 4 of 8
TheCADWhisperer
3 panels? 4 panels?  Base dimension? Height? Truncated or to apex?
Do you have some additional information?  Pictures? Hand sketches?
Can you File>Export and then Attach the *.f3d file of what you are able to complete before the crash?
Message 5 of 8
Yes just one corner.
Message 6 of 8
4 panels, 950mm square, 38mm high to central point same as your model and 0.3 mm thick aluminium. Unfortunately I don't have a file to upload as after 6 attempts I scrapped the idea.
Message 7 of 8
TheCADWhisperer
@Anonymous wrote:
4 panels, 950mm square, 38mm high to central point...
Message 8 of 8
That looks like what I am after. Could you share with me how you achived this?
