sheetmetal normal cut
7 REPLIES 7
Message 1 of 8
349 Views, 7 Replies
is it possible to do cuts on sheetmetal that are normal to the sheetmetal? the laser cutter isnt able to cut under an angle.
7 REPLIES 7
Message 2 of 8
g-andresen
Please share the file and show what you are talking about.
File > export > save as f3d on local device  > attach it to the next post
günther
Message 3 of 8
in reply to: g-andresen
see attachment
Message 4 of 8
g-andresen
To my knowledge, the laser cut is made on the flat pattern and is therefore normal to surface.
günther
Message 5 of 8
TheCADWhisperer
@Anonymous
Do you want the real solution?
Message 6 of 8
in reply to: TheCADWhisperer
if you know a solution that requires less steps, let me know!
Message 7 of 8
TheCADWhisperer
Less than two steps?
Message 8 of 8
TheCADWhisperer
@Anonymous
OK, I was able to get it down to one sketch...
