Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Sheet Metal Wire Edge
1 REPLY 1
grp320
400 Views, 1 Reply
Any advice for achieving a sheet metal wire bead with Fusion360?
Labels (5)
1 REPLY 1
jhackney1972
in reply to: grp320
Here is a model with a wired edge.  You can fill it with a piece of wire if you desire.  I personally do not see any way of creating this edge and still be able to create a flat pattern due to the fact the roll is added as a Sweep feature to an unfolded sheet metal form.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Technology Administrators
