Sheet Metal - update sketch
ilja.coveliers
ilja.coveliers
Hi all,
When I've create a cylinder with sheet metal,
what are the steps for resizing the circle ?
If it was a full circle I could use the dimension tool to change the size,
but since it's a "sheet metal circle", the circle has a straight line and gap in it,
so I can't change the size in an easy way without loosing the sheep metal folding ability,
or is there ?
Probably an easy fix for the experts in here.
Can anybody help me with resizing the circle with the least steps ?
Thanks in advance.
ilja.coveliers
Perhaps it's coincidence or not, but I've tried again and it does work now with the dimension tool,
without breaking the folding.
Last time when I tried to change the diameter with the dimension tool,
it messed up the folding.
Maybe sometimes it works and other times not ?
HughesTooling
As long as the sketch is fully constrained it should resize without any problem. Just make sure everything is dimensioned even the line and gap.
Mark Hughes
Owner, Hughes Tooling
ilja.coveliers
Ok. thanks for the info
