Sheet metal twisted pyramid base for sculpture
3acorns
3acorns
I have made a sheet metal kinetic sculpture somewhat like the one in the link and photo below. I used Fusion 360 to design all of the moving parts. I cannot find a way to design the Twisting base like the one below. This style of base is used by many artists, so there must be a way to design it in either fusion 360 or some other program. Do I need to use Solid works or Inventor? Any help would be greatly appreciated.
https://images.app.goo.gl/PHx4ngja951YsjwT6
Andrew CarsonAndrew Carson
Replies (10)
g-andresen
maybe this?
twisted basetwisted base
günther
3acorns
Thanks Guenther. I'm a beginner, so struggling with creating the 3D spline perpendicular to rectangle sketch. Can you create sheet metal flange and flat patterns for each side of the body?
laughingcreek
You can only convert surfaces that follow the sheet metal rules into a sheetmetal body that can then be flattened.   Your object has compound curves, so fusion won't be able to flatten it.
a possible work flow would be to export the surfaces to mesh mixer and unwrap them.
3acorns
Thanks. I've managed to create the nice twisted bodies, but like you say, can't get them into sheet metal unfolding. There must be a way.
laughingcreek
probably. but probably not with fusion.  post your model, let's have a look
file-export as .f3d
3acorns
Here are 2 attempts.
First file: Created body by lofting along a 3D spline. The 6"x6" base bottom and the 2"x2" top are in the correct locations.
Second file: Playing around and managed to create flanges following a spline and used similar flanges to cut tapers into flanges. Do you see any way to get the first approach to convert to sheet metal flanges? If not, I may be able to piece something together using second approach.
I would appreciate any ideas.
Stars Base3-28-2020 loft body along spline v4.f3d
Stars 03-28-2020 flange along spline v2.f3d
I'm not sure if these files actually attached. Please let me know.
3acorns
Here are the files.
laughingcreek
edit - nevermind, they're attached now
the files didn't attach.
laughingcreek
both your examples have compound curvature, so you won't be able to use sheet metal.  attached is an exampe where I was carfull to NOT have compound curvature, and so was able to unfold it.  it doesn't twist though.  the trade off if yoiu want to only use fusion
also attached is a mesh file where I took the surfaces from your first model and opened in mesh mixer, then unwrapped the surfaces.  this may be better for your purposes.  and it's easier.
3acorns
Thanks for the excellent answer and help. This will keep me busy and learning for a while.
