Sheet metal ring won't unfold.
Message 1 of 15
I found multiple tutorials on how to do this on this support page, but they don't seem to work anymore. I used it once, in an unrelated file, and the screenshot is just of a test file that I made. I will warn you that I am a novice, I have only been using Fusion 360 for a couple of weeks, but I decided to download it to make some rings. I need to put text on the rings. No problem. Here is what the tutorials said to do, as I understood them
-Make a sketch of your ring including the thickness of the ring.
- Draw a radius line
-Draw another line, using the offset tool a small distance away from the radius
- Trim the outer circle between the lines
-Create a flange out of the trimmed, circular face
-Extrude it to your desired height.
-Extrude the one of the faces of the cut section partway through the gap, using join so that it creates a small rectangular prism
-Go to modify (in the sheet metal work space) and click unfold bends.
-Select the outside face of the rectangular prism, and the outside, curved part of your ring as the bend.
-Add your text as a sketch to that face
-Refold the ring, and extrude your text.
If you look at the attachment, I followed those steps until I got to the small rectangular prism that was extruded from the cut face. However, I can't select the rectangle as the stationary entity as I'm supposed to be able to, or select the outer, curved face as a "bend". As I mentioned, I have followed those exact steps in the past, and it worked great. I have no idea why I can't select the correct faces.
Thanks in advance for the answers.
Replies (14)
Message 2 of 15
etfrench
Most likely reason is you probably did a Press/Pull instead of an Extrude. Note the difference between your image and the extrude operation in the screencast.
ETFrench
Message 3 of 15
JDMather
What are the links for the Tutorial references?
File>Export and then Attach your *.f3d file here and end all doubt.
Message 4 of 15
Here is the f3d file. Thanks again. This is just a test file where I followed the steps that I described above exactly. Make two circles, trim a small bit out of your ring, try to make a flat fact to set as the stationary entity, and I can't select the flat face.
Message 5 of 15
@JDMather wrote:
What are the links for the tutorial references?
Sorry I didn't understand what you meant. I tried checking back to where the tutorial that I used was, but it looks like it got taken down for some reason. I can't find the same thread that was usually first in my results when I search "text on a ring fusion 360 ." Anyway, I'm sure that you could find a very similar tutorial if you just search what I did.
Message 6 of 15
g-andresen
you´ve to choose the right profile!
screencast
günther
Message 7 of 15
TheCADWhisperer
@Anonymous wrote:
... but it looks like it got taken down for some reason....
Perhaps because it was all wrong.
When I get a chance I will make a video on how to properly create this part (actually - I already made the video some months ago and posted it here, but now I have to locate it).
Message 8 of 15
etfrench
  1. -Make a sketch of your ring including the thickness of the ring.
  2. - Draw a radius line
  3. -Draw another line, using the offset tool a small distance away from the radius
  4. - Trim the outer circle between the lines
  5. -Create a flange out of the trimmed, circular face
  6. -Extrude it to your desired height.
  7. -Extrude the one of the faces of the cut section partway through the gap, using join so that it creates a small rectangular prism
  8. -Go to modify (in the sheet metal work space) and click unfold bends.
  9. -Select the outside face of the rectangular prism, and the outside, curved part of your ring as the bend.
  10. -Add your text as a sketch to that face
  11. -Refold the ring, and extrude your text.
Step 6 is where the instructions are faulty.  In Step 3 create the flange with the distance set to the width of the ring (see my earlier screencast).
ETFrench
Message 9 of 15
TheCADWhisperer
For me Step 1 is wrong.
Message 10 of 15
etfrench
True Smiley Happy
The thickness of the ring is set by the Sheet Metal rules.
ETFrench
Message 11 of 15
g-andresen
günther
screencast
Message 12 of 15
Ohhhh. I think I know what I was doing wrong. When I want to decide the thickness of the ring, I have to use the sheet metal rules to do that, I can't just have two circles the width away. I have to select an edge not a face when I create a flange. If I'm wrong, thank you for bearing with me, and please tell me how I'm wrong. If I'm right, please tell me how to modify the sheet metal rules. I just want to make sure that I know how to set the thickness of the flange. Thank you all, you've been super helpful so far.
Message 14 of 15
TheCADWhisperer
Step 1. Sketch desired profile (single edge - Sheet Metal Style will determine Thickness).
Step 2. Flange (see Attached *.f3d file).
Message 15 of 15
THANK YOU ALL SO MUCH!!!! You've solved my ignorance of how the program works.
