sheet metal library and "in design rules" interface
Garret_H
Garret_H
Please add "in design" sheet metal rules to the pull down menu when creating new parts.
As of the latest update the pull down only consists of the default, and select from library.
The whole point of a pulldown menu is to select recently or frequently used options. I don't want to have to navigate through my library just to select the same rules I have been using elsewhere in my design.
Then there is the library itself. Its slow and laggy,  the default width of the "name" column is too narrow. It always defaults to selecting "default rules" from the public library.  Its all adding features that require more navigating through menus and distracting pop-ups.
There is more and more Inventor creeping into my Fusion workflows, there is a reason why I prefer to work in Fusion and this isn't it.
Garret_H
Can this get fixed already? I am  working in a "hybrid design" creating a weldment of multiple sheet metal parts.  I can't select the same rule I just used on the last part I created and have to navigate through the laggy sheet metal library involving multiple clicks.  The implementation of this new feature is just a total downgrade.
