Having a issue trying to get this part to unfold. Keep getting told this object is not connected to any bends.
I also want to put all my trim points for the welds in 4 places in the center of the bends, but I can mess with that later once I get it flattened.
I was following this video but hit this hiccup.
https://www.youtube.com/watch?v=oGwn6SsyPwA
Solved by jhackney1972. Go to Solution.
You were following him a little to literally. When he thickened the surface, he thickened it to the outside which happened to be a negative number. Yours on the other hand is a positive number. Just edit your Thicken timeline step to positive and you are good to go. Your model flat pattern is shown below.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Sounds like I will have to restart the process and draw it from ID dimensions of the transition instead of the out dimensions to get it to the proper size? I wish these were editable dimensions I have to do these so many times.
My round was 8.625
The rect was 13.5 x 17.125
I saw one of your videos on the file with a fully defined one. Do you have a link to that file I can play around with? Not sure if you shared it here but having to search through a few thousand post is no fun.
Thanks a ton @TheCADWhisperer . The one you have makes it a breeze, but I cannot figure out that surface trim tool. We usually cut these things on the 4 right corners so they are easier to make. Do you have a idea how to do that?
I keep getting there is no visible surface to trim when trying to edit it
