Hi
I'm struggling with how can I make additional 90 bent perpendiculars to the existing hemming bend.
Stainless steel 2 mm and 3 mm
Solved by jhackney1972. Go to Solution.
Can you hand sketch your intended flanges and attach the image here?
Here is your model with the bend you specified. The Bend Radius can be varied within reason. If you cannot follow the timeline, let me know.
John Hackney, Retired
