sheet metal flange
sheet metal flange
brianW8BLZ
Message 1 of 12
sheet metal flange
brianW8BLZ
coming from solidworks this is a simple task just edit the sketch of each flange to clear each other and you done
I have tried multiple ways to do this in different timelines and I cannot figure it out  I need all flanges bent to  90 deg.
Replies (11)
Message 2 of 12
Warmingup1953
I assume you don't mean like this?
Can you elaborate?
Message 3 of 12
brianW8BLZ
no  I need the one flange bent to 111 deg. and the other 2 to 90 deg.
Message 4 of 12
TheCADWhisperer
@brianW8BLZ
Model in finished form.
Message 5 of 12
Warmingup1953
I'm sure there is a more elegant way.
Message 6 of 12
brianW8BLZ
here is what I am taliking about the 2 side are bent to 90 deg. and the front to 111 deg. the one corner has all of the interference that i cannot solve
Message 7 of 12
Warmingup1953
Updated sides
Message 8 of 12
brianW8BLZ
this is correct  That is crazy how you achieved it
Message 9 of 12
johnsonshiue
Hi! It is true that there isn't an exact SWX-like workflow in Fusion in this case at the moment. However, it isn't too difficult to create individual Flanges with asymmetric offsets. Then use Corner Closure to heal the gap. There is no need to use Surface Modeling workflows here. Please take a look at the attached f3d file.
Many thanks!
Let us know how we did on Trustpilot.
Software Test Engineer
Message 10 of 12
brianW8BLZ
how did you do the 3rd edge flange, not the entire way of the material?
Message 11 of 12
Warmingup1953
Thanks for that.....I must have missed the arrival of corner closure...This is a great help!
A link to the Brad Tallis video that explains it very well.
Corner Closure
Message 12 of 12
johnsonshiue
Hi Brian,
You will need to select a width option allowing the Flange to run partially on the selected edge.
Many thanks!
