SHEET METAL error - Fusion
xbodis
Message 1 of 12
xbodis
Hello everyone,
I’m having a problem with the Sheet Metal Flange feature, specifically with the Two Offsets option. I didn’t have this issue before the latest update, but after updating I’m getting this error every time.
I enter all my inputs correctly, select OK, and the flange is created. However, when I try to edit the flange again, Fusion shows an error. Edge 2 and Edge 4 always lose their offset values after reopening the feature. I have to reselect the full edge, re-enter both offset values, and confirm again. When I reopen the flange, the same error appears.
Please help.
Thanks!
This post has been edited due to: @heather_tracy added the product to the title to help more community members find this topic.
Replies (11)
Message 2 of 12
Warmingup1953
Share your Fusion file?
Message 3 of 12
johnsonshiue
Hi! Either the neighboring Flanges are colliding or the Bend Relief or the Corner Relief setting is incompatible with the Flanges. Try changing the width option to narrow the Flange width, allowing more room for neighboring Flanges.
Please feel free to share the f3d file here or send it to me directly at [email protected]. I would like to understand the failure better.
Many thanks!
Software Test Engineer
Message 4 of 12
aaronzpaul
Community Visitor
Community Visitor
Hi, I'm facing same issue,
Fusion allows you to create a "Two Offset" flange with two or more edges but when you try to edit it, it shows the error message as shown in the screenshot.
What I noticed is when only one edge is selected this issue does not occur, add a second edge and the issue occurs.
Pic_1 Show the edges that are selected.
Pic_2 show the error message and the flanges are missing.
Tried with the built-in sheet metal rules - the issue persists.
The "Two sides" flange option does not have this issue.
Fusion version:  2605.1.39 x86_64
Message 5 of 12
johnsonshiue
Hi! If possible, please share the f3d file here. It will help us understand the issue better.
Many thanks!
Message 6 of 12
aaronzpaul
Community Visitor
Community Visitor
I have attached a test f3d file, that reproduces the issue.
Message 7 of 12
johnsonshiue
Hi Aaron,
This is absolutely a bug. I will work with the project team to understand it better and see how we can resolve it asap.
Many thanks!
Message 8 of 12
johnsonshiue
Hi Folks,
This is indeed a known issue and it has been fixed on an internal build targeting the next update.
Many thanks!
Message 9 of 12
xbodis
Thanks for your repleys!
But im still facing the same issue...here is my file so you can chceck it out.
Message 10 of 12
johnsonshiue
Hi! This is the same issue unfortunately. It will be fixed in the coming update.
Many thanks!
Message 11 of 12
xbodis
Just want to ask, how is it looking with fixing the bug?
Thanks!
Message 12 of 12
johnsonshiue
Hi! I just tried the workflow on the latest internal Fusion build (targeting the coming major update). The issue is indeed fixed there. I believe it will be fixed on the coming update.
Many thanks!
