Share public link options.
JYZMT
JYZMT
I'm starting to use the share public link function. Its proving useful, but I have two questions.
I don't need (if fact I do want to) share the cam space with some people. Can I stop sharing this and only share the model space?
Is there any way, or an add-in, or anything where I can let the viewer of the public link edit a few chosen parameters? Say favorites parameters? I doubt it, but it would be enormously useful if it could.
lucasliraAU
Hi @JYZMT
Thanks for reaching out to us on the forums!
Here's some information about your questions:
Regarding the sharing of a part with the CAM parameterization function activated.
Whenever you create a SETUP and then create a MACHINING course this will automatically be stored in the information of your part.
If you want to share this part without SETUP recorded I recommend you execute and delete it and then do the sharing;
For the second question - On the A360 platform you have access to your project in a web browser. The platform has resources for managing your work, note in the image below where I am performing the addition of communication point for future changes to another member of my team.
This is the best resource for you to use in a collaborative project.
Hope this helps in your future work!
Did you find this reply helpful ? If so please use the Accept as Solution or LIKES button below.
Si esta respuesta te ha servido de ayuda, por favor márcala como Solución Aceptada o dale a LIKES
Lucas Lira - Fusion 360 Technologies, Design and Applications - Autodesk Hub Diamond
Direct contact at: https://www.linkedin.com/in/lucaslirasantos/
VEX Robotics Engineering in Brazil - https://www.vexforum.com/u/lucas_lira/summary
Main Researcher and Technology Applications in Nerd Factory - https://www.fabricadenerdes.com/
