Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Shape optimization. Error. Need help. OCM convergence
2 REPLIES 2
fundamental4
340 Views, 2 Replies
Hello all,
(Beginner with shape optimization).
I'm trying to run the optimization but I obtain an error. If I run just Load Case 1 is fine, but if I include Load Case 2 I receive the error.
Load Case 2 is clone of number 1, the only change is the  direction, Linear Global Load X is in the opposite direction (same value).
attached error file.
file: https://a360.co/2IQR1B0
Thank you.
2 REPLIES 2
I_Forge_KC
in reply to: fundamental4
The second load case is an exact copy. When you change it to (+)5 instead of the (-)5 you get a result.
Notice the two arrows are opposed.
K. Cornett
Generative Design Consultant / Trainer
fundamental4
in reply to: I_Forge_KC
Thank you for your reply
