Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Shall I buy a lot more RAM?
8 REPLIES 8
Message 1 of 9
ash2020
4237 Views, 8 Replies
I'm running Fusion on a 27" IMac 5K . Is has a 3.3 GHz Intel Core i5 but at the moment I only have 8 GB RAM. Would it be a huge benefit to double or even quadruple the RAM? Bearing in mind that it costs quite a lot!
Cheers
Andrew
8 REPLIES 8
Message 2 of 9
aaronkcap
in reply to: ash2020
From my experience not very unless you are working on models that have well over 500 parts then you should be fine
Message 3 of 9
ash2020
in reply to: aaronkcap
Thanks, I was hoping that would be the answer 🙂 I will get more as I can afford it.
Andrew
Message 4 of 9
Hello!
Are you experiencing issues with your current specs on Fusion 360 Software? Sounds like a really nice machine and it should work flawlessly as long as there are not a lot of parts in your project (Simple project).
Message 5 of 9
ash2020
Hi there.
I do seem to have fairly frequent crashes. I just tried the Fusion logo tutorial and it crashed several times, especially when creasing. The display is totally gorgeous though!
Message 6 of 9
aaronkcap
Have you submitted the crash log to autodesk; they have been super helpful with things like that for me. I have a mac with an i7 and 16gigs of ram from mid 2013 where I was running into the same issue and it turns out that there was a setting that needed to be changed. I wish I still had the email or I would tell you what it said.
Best,
Aaron
Message 7 of 9
Hey there @ash2020
Have you tried the limit effects options under help menu > graphics diagnostics? Here's a screenshot of my software so you can check out if you got it ticked. It works wonders
Although I would not recommend it, you could turn off the History of parts too. Maybe just making them not visible while you're not using them.
Hope this helps!
Message 8 of 9
ash2020
Thanks Aaron, I'll definitely do that.
Andrew
Message 9 of 9
ash2020
@Anonymous wrote:
Hey there @ash2020
Hope this helps!
I didn't realise you could do that. Thanks. I will try it and see if it speeds things up.
