Shaded View Problem
Shaded View Problem
Markclayto
Shaded View Problem
Markclayto
I have created a shaded drawing view the shaded infill is off centre to the wireframe out line.
Just looks like a bitmap image has been moved off the wireframe outline.
I have tried all sorts to correct it but with no luck any ideas.
Kind Regards Mark
zhixin.ni
There must be something wrong with the software. Can you try to edit the view by double clicking it, switching the Styles in the dialog, but still keeping Shaded style when you close the dialog.
If the issue still exists, could you share your drawing to zhixin.ni@autodesk.com for me to further investigate it? (Please Open Details on Web through the drawing on the data panel and share the drawing in the web page)
Thank you
Regards
Nick Ni
Markclayto
Hi Zhixin,
What you suggested does not unfortunately wok for me could my software still be an issue I could do a clean install.
I have sent you a link to the drawing.
Kind Regards Mark
I'm experiencing a similar problem. The drawing view is in isometric, but the shading is coming through in perspective, so is misaligned. I wonder if it is remembering the perspective settings from when it was rendered?  The model view was set to 'Perspective with Ortho Faces', changing this to 'Orthographic' had no effect.
I don't see a solution to the original problem.  I just created a 2D drawing from my model and wanted the shaded option.  The shaded image is outside of the drawing lines, basically off-center.  This didn't happen on other drawings of mine, but I noticed it here.  What is the issue and fix?  I've attached screenshot and public link below for my model.
https://a360.co/2KLkkFY
