Project design structure plan - request for review
drew
drew
After a few (well, many) preliminary explorations of how to create different parts of what I am designing, I am setting out to do the 'real thing'.
I am requesting comments on how I intend to structure the Fusion360 file types and hierarchy.
MAIN PROJECT
>MAIN DESIGN (which is, if I understand it, actually a component but is the topmost one)
    contains main design items needed by many components, bodies, or sketches
    contains the user parameters that will be used in various sketches/bodies/components
    also includes overall elevation and plan views that will be used (traced) to create sketches inside other components
    this is where the subassemblies are assembled into the whole thing
          >SUBASSEMBLY_A COMPONENT
            an assembly of other components created within this component, but has no bodies of its own
            may have sketches needed by the components inside this component
                         >COMPONENT OF SUBASSEMBLY
                         will contain its own sketches and bodies plus more components
                                        >COMPONENTS (if needed as independent 'jointable' objects within the above component)
                                          each will contain its own sketches and bodies
           >SUBASSEMBLY_B COMPONENT
                                        >COMPONENT(S) (if needed as independent 'jointable' objects within the above component)
Is this the correct structure?
Am I asking for trouble by nesting components?
What to do if this is not the proper approach?
Cheers for replies,
Drew
(Edited for typo)
TrippyLighting
Here's a link to the handout @jeff_strater and I created for the class we taught at Autodesk University.
It has a section on Assembly Structure that addresses you questions (and if not I'll improve it so it does!).
It's probably not a bad Idea to go through the whole thing as it will help you avoid any pitfalls!
drew
Holy WOW, Peter, that's an awesome doc. Thanks!
So, yes - my plan for organising this is appropriate, and it looks like I have pictured the relationships between the 'levels of containers' the proper way.
Again, thanks for linking to that - I am really surprised it isn't one of the first things you get when Googling for Fusion stuff on the web.
Maybe you can get it more visibility somehow? I'm certian a lot of newbies would love to read that instead of aimlessly watching hours of videos that don't succinctly explain stuff.
TrippyLighting
Your structure abov is OK with the exception that a subassembly should only contain other components, maybe sketches, but not bodies. Or in other words you should not have a bodies folder and a component at the same level in an assembly.
