settings bugs in Motion Study Cloud Rendering in Fusion 360
A couple of issues with Cloud Rendering a Motion Study in Fusion 360 (release 2.0.1774). Most of which have to do with persistence of settings.
When I change the name of my motion study in the Model view, the name of the motion study does not change in the Cloud Rendering settings.
The bigger problem is that I can't get the Motion Study Cloud Rendering button to appear (the little play button next to the Turn Table button in 'Render as'), unless I render a preview video out.
For example. If I click on a previous render, I do not see the Motion Study Cloud Rendering button:
But if I create a new video (what does that even mean, by the way? The end result is not a video).
Then when I click on the output of that (an image), I get the button. I have not seen what happens if I just create an image, rather than a video, but I expect it to be the same.
But now that I have the button, I can't really change settings. For example, if I wanted custom dimensions, I can make it a "custom" format, but there's no place to adjust what that actually means. Is there?
The other frustrating part is that the view doesn't change unless I create a fake/preview render first. In other words, if I continue to just hit the Motion Study Cloud Rendering button, while changing the view/moving the camera, nothing actually changes. It only changes view when I create another cloud render, and then it adopts those settings.
These are workarounds, for hopefully known issues. Is there a better way to do the things I'm doing?
Xiaoqing_Zhuang
Hi Jimmychion,
This is Xiaoqing from Fusion 360 cloud rendering team.
Firstly thank you very much for using Cloud rendering feature and report this issue. Apologize for this inconvience. This is known limitation of cloud rendering in Fusion 360. Your workarounds are the ways to cover this known limitation.
The improvement of motion study rendering in cloud rendering is planned. We will keep you update on the improvement release in the future.
By the way, do you mind to participate our usability test of cloud rendering in future.
Your report is appreciated. Hope cloud rendering is helpful to you and feel free to contact us for issues and questions.
Best Regards
Xiaoqing Zhuang
Xiaoqing_Zhuang
Looks great!  Thanks, Jimmy
We will link your instructable in our forum so that other users will be able to get this workaround
