Problem with selection and scale
fritter63
fritter63
See screen cast. Can't select a sketch object(s) to scale at all.
https://knowledge.autodesk.com/community/screencast/39aa77fb-b13a-4af3-9dcf-745d213c18f3
masa.minohara
Are you able to select Sketch1 or 2 in the Browser instead of Selection set? Currently you can select Sketch only from the Browser but the enhancement request for Sketch scale has been accepted so it will be available in the future update.
http://forums.autodesk.com/t5/ideastation-request-a-feature-or/add-scale-and-rotate-to-the-sketch-to...
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
fritter63
Yes, I eventually stumbled on the fact that you can only select the sketch.
That is ridiculous! That means if I had a fretboard of inlays, I'd have to put EACH inlay in it's own sketch to resize them. Glad you have fixed that. Do you know when the
fix will be released?
fonsecr
Just an FYI for everyone that this issue was fixed last year per @jiang_peng. I dont have the exact version but doesn't really matter since all are using latest release 🙂
René Fonseca
Software Architect
