setting hole on a sketch point
fsonnichsen
fsonnichsen
I've done this before  but since an upgrade this is not working--I want to set a point on a rectangle in a sketch. Then I extrude the result and want to set a hole on the point. The hole does not want to snap to the point. Been a while since I used 360 but I am pretty sure this worked before. (see attached)
thanks
Fritz
jhackney1972
It works without issue for me.
Edit: I am using the latest Fusion 360 version.
John Hackney, Retired
etfrench
Works for me as well.
ETFrench
fsonnichsen
thanks. Apparently the order matters--select the points, then the hole command.
