I am trying to create a threaded hole through the side of an internally threaded cylinder for a set screw, but Fusion fails every time I try to do this. Attached is an image of the error as well an example model. In the attached model I am trying to add 1/4-20 threads to the 1/4" hole.
Unchecking the Modeling attribute on the main thread allows the set screw thread to be created.
If you want the main thread to be modeled:
This worked for me, hopefully, you'll have the same success.
ETFrench
