I created a box and made separator / dividers, instead of putting text on each, I have a 3 sided slot to slide the card in. I created 3 different sketches for the different layers.
I was watching something similar that was created in TinkerCAD, but it was done completely different. The main body and then 2 "cut" objects. Moved / centered into place, item complete.
I have tried different with the objects all in the same sketch but can't get with the cut objects. "Target not selected...", I did get similar with creating different sketches for each item.
Is there a "proper way" to do this ?I'd like to learn the correct way and not just "as long as it looks like I want it to"...
