Can't export files
Can't export files
jeffescott
Advisor Advisor
Message 1 of 10
Can't export files
jeffescott
I have been working along fine, modifying my design, then exporting it has an stl.  Then 3d printing it with prusa.   This has been working for at least the last week.
All of a sudden I can not export an stl file.  Fusion sits there for at leas 15 mins with the circle of death revolving. If i click anywhere the browser bar background turns black.  Then if i click again I get the message program not responding.
I am working on line and the internet connection is fine.
Since i don't get to the prompt that allows me to select the file type I wish to export, I also can't attach a file to help.
Any ideas?
Replies (9)
Message 2 of 10
jhackney1972
If you are not, try right clicking on the body, component or assembly and use the Save as Mesh command.  You have a lot more options than trying to Export.
John Hackney, Retired
Message 3 of 10
jeffescott
i opened the save as mesh and was trying to work through the selections and fusion stopped responding again....I also tried to repost a simple nc program again fusion stopped responding.
Message 4 of 10
jeffescott
tried an old project same problem.
Message 5 of 10
jeffescott
checked again job status is working on line, and no notifications,  i am updated.
Message 6 of 10
jhackney1972
Maybe it is time to visit the Fusion Service Utility and the Repair Option
Message 7 of 10
jeffescott
Yeah thanks for the link I was wonder how to get there?
Message 8 of 10
jeffescott
OH OH  i launched the repair option, and now fusion is missing a file to open. and the launch utility wont open?
Message code execution cannot precede because Qt6Gui.dll was not found.  Reinstalling the program may fix this problem.
What now?
Message 9 of 10
jhackney1972
Edit: I forgot, please go to Control Panel and see if you can Uninstall the existing Fusion application.
(Please read completely before proceeding)
As it says, you will need to reinstall the application.  If you are on Windows, this is how I would proceed.  Make sure EVERYTHING on your computer is closed including your Anti-Virus software.  I would then go to the following folder and the folder called Webdeploy.  The indicated user name will be replaced with yours.  A quick way to get this this folder is to open up File Explorer and type %localappdata%.  This also assumes you have Show Hidden Folder enabled in your File Explorer.
Next you need to log into your Autodesk Account and download the Fusion Installer.   The address in shown in the screen capture.
Once there you will find Fusion and click to download the installer.
Once you have the installer EXE, right click on it and choose "Run as Administrator" from the context menu.
Before running the installation routine, make sure everything on your computer is not running including Anti-Virus software.
If you are using a MAC, I cannot help.
Message 10 of 10
jeffescott
okay I have fusion reinstalled.... I managed to create an stl file.  So wow scary.
Thanks for your prompt help....I ended up in the chat assistant, was looking at two buisness days for help.  Thanks again
