Sending objects from Tinkercad to Fusion 360 nothing happen
Message 1 of 31
I want to import my objects form tinkercad to fusion 360 with the new "send to Fusion 360" function.
Everytime after i push the button "Open in Fusion 360" the window appears like in the picture below and nothing else.
Here is the link from Tinkercad:
https://blog.tinkercad.com/2018/07/16/tinkercad-send-to-fusion-is-live/
I tried:
-just a simple cube and other basic shapes
-reinstalling Fusion 360
-chrome as browser
Win 8.1 64Bit
Firefox 63.0.1 (latest)
Nvidia 8.1.940.0 (latest)
I dont want to import it to Fusion as stl or object, because of the quantity of the objects i want to have send to Fusion.
Anyone knew this kind of problem?
Replies (30)
Message 2 of 31
HelenChen-AutodeskQA
Hello rave.gt,
Sorry to hear that you are having trouble.
After you clicking Send to Fusion button, you suppose to see a pop up dialog "Launch Application" where you could click send the file to NLauncher Application, then it will open Fusion 360 with your Tinkercad model.
Please check whether the pop up dialog is blocked by your browser, if yes then please enable the pop up dialog and try again.
Hope it helps. Thank you.
Helen
Helen Chen
Principle QA for AutoCAD Windows
Message 3 of 31
Hello rave.gt,
Are you still reproduce this issue?
Could you please try to restart your machine and try again? Thank you.
Helen
Helen Chen
Message 4 of 31
already checked that but the Nlauncher dont work, not even after reinstalling Fusion.
I got my f3d files by extracting the download link from the html editor and decoding the html for download regulary.
But in future it would be nice to know why the Nlauncher dont work??
I also tried to open with fusion360.exe but fusion just started without loading something....
Maybe a issue with decoding the link for Nlauncher? -> I even didnt get a started process in task manager....
Any ideas?
Message 5 of 31
bourno
Took a few tries, but the NLauncher did start to work for me, and seemed to stay working. Not sure what changed. Sad part, and reading the article over again, is that it works for "basic primitives".
Unfortunately, me and my friends use higher res parts for spheres, cylinders, etc to reduce flatting and facets. I have been using Fusion for 2 years, but still have some friends who do most of their playing in TinkerCAD. Wish this had been available like 2 or 3 years ago, lol. Does take the old TinkerCAD primitives to a whole new level of "holy ****, that looks good now".
Attached a snip of a part made with higher res pieces, which doesn't convert over.
I would loved to edited it in Fusion to add some easier Filets. And a snip of Low Res moved over, and quick little filets and chamfers, just to see. No History Timeline and edits go into the Body list.
Message 6 of 31
Hi, I am having a similar issue. I have enabled popups, restarted etc but I can't even get the Launch 'Application' or 'Opening your design in Fusion 360' popups shown in the first post of this thread. I just get a message of 'Sorry, we were not able to send your design to Autodesk Fusion 360 at this time. Please try again.'
Message 7 of 31
Having same problem here. Tried enabling pop ups, made a project with only cylinder, tried selecting selected images, nothing seems to be working gettings same pop up message.
Message 8 of 31
I'm having the same problem, even just sending a basic cube doesn't work
No pop up appears, but my browser (Chrome) isn't showing as blocking anything
Message 9 of 31
Sorry for any inconvenience and thank you very much for your reports, we are investigating this issue and will keep you be posted.
Helen
Message 10 of 31
Hello all,
The workflow of sending Tinkercad to Fusion is back to work today.
Could you please have a double check? Thank you.
Sorry for any inconvenience and thank you very much for reporting us.
Helen
Helen Chen
Message 11 of 31
Works perfectly, thank you
Message 12 of 31
Hello, yes it's working now, thank you so much!
Message 13 of 31
bourno
I wish Fusion had a simple method to import STL files as a solid object versus a mesh.  One of the nice things about TinkerCAD 🙂
Message 14 of 31
I got the same problem, i can't send anything to Fusion 360, from Tinkercad.
I have tried with both Chrome and Internet Explorer, but nothing happends.
Message 15 of 31
Hello jnse78
Sorry to hear that you'r having trouble.
From Tinkercad to Fusion works well for me now.
Could you please restart your machine and try the workflow once again? Thank you.
Helen
Helen Chen
Message 16 of 31
Work as expected! Well done and thanks for all.
Message 17 of 31
Same error here, tried with IE and Chrome on my Windows-PC,  Safari and Chrome on my MacBook.
Message 18 of 31
andreaz.karlsson
Observer
Observer
HI, I am also getting this error 😞 have tried everyting as listed in previous conversation (and yes I have restarted my comfusor 🙂 )...
BR
Andreas
Message 19 of 31
Hello. I am getting the same exact error as of today April 10, 2021 in Canada. Can you please investigate the issue? I switched to different browsers but still getting the same error. Thank you.
Message 20 of 31
Hi @Anonymous ,
Sending Tinkercad to Fusion 360 might be failed when there is an pending update for Fusion 360.
If that's the case, please wait for the live update download finished for Fusion 360 and then restart it, then try again.
Hope it helps.
Helen
Helen Chen
