Sending objects from Tinkercad to Fusion 360 nothing happen
Message 1 of 28
I want to import my objects form tinkercad to fusion 360 with the new "send to Fusion 360" function.
Everytime after i push the button "Open in Fusion 360" the window appears like in the picture below and nothing else.
Here is the link from Tinkercad:
https://blog.tinkercad.com/2018/07/16/tinkercad-send-to-fusion-is-live/
I tried:
-just a simple cube and other basic shapes
-reinstalling Fusion 360
-chrome as browser
Win 8.1 64Bit
Firefox 63.0.1 (latest)
Nvidia 8.1.940.0 (latest)
I dont want to import it to Fusion as stl or object, because of the quantity of the objects i want to have send to Fusion.
Anyone knew this kind of problem?
Replies (27)
Message 21 of 28
Hello
When I try to send an object from TinkerCAD to Fusion, it asks to open Fusion on the desktop, but I need to use it on the online version (I use linux and there is no Fusion there so I need to use it online). Is there a way ?
thanks
kind regards
Dom
Message 22 of 28
user95007
Community Visitor
Community Visitor
Same issue here, on 2 computers, on which 1 of them was the one i used before. Now the popup does not show and cant select anything, theres only a waiting animation after pressing send.
Message 23 of 28
nicolajgnh
Community Visitor
Community Visitor
Have a similar issue on my laptop.
On my desktop fusion does open, but plate is empty. I think it'd be better just stating that this feature is super unstable, it works when it works, when it doesn't work you'll just have to wait until it does again.
Yesterday i couldn't send any object to fusion, today they work again. Except one, the one that i am working on and actually need to send. If i copy that object, and insert inside a different project that successfully can be sent to fusion. And i then send that object to fusion, then it works. But if i try to send it from within the original project, it does not work. All i did was ctrl+c.
I've experienced multiple times where you get errors on object, which earlier was sent to fusion just fine, a day later it works again.
Message 24 of 28
fablabjen
Community Visitor
Community Visitor
same problem, and fusion opens, but nothing ever appears. the part never transfers, and on retry, it chases it's tail for a sec then stops, but nothing happens, not even a dialog or an error message
Message 25 of 28
jvzilen
Community Visitor
Community Visitor
I am having this same issue.
Message 26 of 28
TheCADWhisperer
@jvzilen
What if you drag and drop the file into your data panel and then open with Fusion?
Message 27 of 28
jvzilen
Community Visitor
Community Visitor
How would I do that?
Message 28 of 28
TheCADWhisperer
@jvzilen
Can you Attach your file here?
