Send 3d print to cura
Message 1 of 11
In the new release of Fusion, I can't get the 3D print to send to cura, what do I have to put into my preferences for the path and executable. I normally use a batch file to start it with the follwing line
@python\python.exe -m Cura.cura %*
STL files in windows are associated with pythonw.exe
Won't work with python.exe or pythonw.exe
In regedit it seems to use this for the STL association:
"C:\Program Files (x86)\Cura_14.09\python\pythonw.exe" -c "import os; os.chdir(\"C:\Program Files (x86)\Cura_14.09\"); import Cura.cura; Cura.cura.main()" "%1"
Replies (10)
Message 2 of 11
innovatenate
Autodesk Support
Autodesk Support
I'm having some difficulty following the procedure you're using. Would you mind providing some further background information on how this process worked prior to the update? Is this being done throught a script/Fusion API or through the User Interface?
Thank You,
Nathan Chandler
Principal Specialist
Message 3 of 11
TimeraAutodesk
@Anonymous Change the print utility dropdown to Custom, and then use the file navigator to browse to executable on your hard drive. This will pass your STL's to Cura. Screen Shot 2014-11-18 at 1.11.20 PM.png
Message 4 of 11
Thanks for responding guys, I am using the new update of Fusion and there is an option to send to Cura. I selected that option but then I also entered a path.
Just tried it again by selecting Cura and leaving the path blank and it works perfectly. I should have just done that in the first place!
Message 5 of 11
TimeraAutodesk
Glad to hear you got it working with the new update!
-Timera
Message 6 of 11
gautham_kattethota
Invoking Cura from the command line involves some arguments as you have noted from its entry in Regedit.  If Cura is installed on your machine, Fusion should pick it up and add it to the dropdown.  That is the best way to invoke Cura from Fusion.  The custom field is useful to invoke print utilities by specifying the path to its exe.  Cura is different in that it requires python to be executed and passes some arguments to invoke the application.
Anyway, I am glad to hear that you were able to invoke Cura from Fusion on your machine.
Regards
Gautham
Gautham Kattethota
Software Development
Message 7 of 11
2herds
Just downloaded CURA 3.2.0 and tried to get a simple STL file to it and could not.
Exporting to a MacBook Pro.
Tried various settings, one being the "General" setting in CURA and it did NOT even look like the one shown in the help picture.
Any ideas would be helpful,
Message 8 of 11
Message 9 of 11
2herds
Don't remember what I did but it works fine now.
@Anonymouswrote:
you have a registry key to modify :
https://forums.autodesk.com/t5/fusion-360-support/fusion-360-not-sending-to-cura-3-0-4-pc-or-mac/td-p/7561395
Message 10 of 11
I do not have that option to even select a 3D Print Utility software. Cura used to be an option until the update.
Message 11 of 11
2herds
Beginner with Fusion, but I wll try to answer. Not totally sure what or where the problem you are having is being caused.
I just made a cube in Fusion (new updated version via UI), went to Body to generate a STL file. Window then came up where I was able to create and transfer the STL file to my directory. Opening CURA 3.6.0 I was able to select the file and present it for slicing.
Also from the Body > STL window selection I was able to select "send to 3D utility" box, then CURA and a few others came up for selection.
Using Apple Macbook Pro OS 10.14.1
