Selection set missing isolate
ELAFING
ELAFING
I created a selection set and the right mouse button drop down menu seems to be missing some options.
jeff_strater
depends what is in the selection set.  A selection set is really just a shortcut for selecting everything inside of the selection set.  The context menu is, well, contextual, and will react to the intersection of everything that is selected.  If your selection set contains an item that does not support Isolate, then that command will not appear in the menu,
Jeff Strater
Engineering Director
ELAFING
Got it, thank you.
