I need to select 200 small holes to laser cut.
How do I do this without having to manually select each one of them?
Solved by chuck767. Go to Solution.
Solved by HughesTooling. Go to Solution.
I export a dxf sketch of the object face, the Laser software does the rest.
Might help....
@chuck767 Think from your previous posts you're doing the laser cutting in Fusion?
If You have all the circles in one sketch you can select the sketch in the browser, just make sure there's nothing else in the sketch.
Or better still, if you've modeled the part you can select the face the set to inner loops.
Mark Hughes
Owner, Hughes Tooling
Mark
You nailed it. This is exactly what I was looking for.
Chuck.
