Selection Filters: A Quicker Way to Hide Joint Icons
tookemtoni
tookemtoni
Selecting joint icons to hide them is quite tedious. Is there a quicker way? I would love to have a keyboard toggle set to filter joints (or any other element).  Like we use the keys 1, 2, 3 (window, paint, freeform) for the selection styles.
See demo video. FYI I am using the V key to hide the joints
TrippyLighting
Object visibility settings. I would personally prefer to have to do less clicking to access those.
Maybe not a keyboard shortcut, but have them accessible at the bottom of the screen.
TheCADWhisperer
@tookemtoni
Why not simply click on the eyeball in front of the Joint Folder?
or
for specific Joints
expand the folder and Shift or CTRL select (I assume there is a similar CMD technique on Mac.
I feel like I must be missing something.
TrippyLighting
@TheCADWhisperer wrote:
@tookemtoni
If you have an assembly with multiple linked subassemblies, or you work a lot with explicit joint origins, also in nested in linked components, then having a global on/off toggle  definitely helps.
tookemtoni
Hey @TrippyLighting,
Thanks for bringing that "object visibility" setting to my attention. I did not know about that. It would work except there's one important joint that I need visible to control these multi axis hinges. See video demo.
I think I also just need to be more vigilant about hiding the joints in the assemblies and subassemblies and xrefs.
g-andresen
Create a hinge with all joints including the limits of motion, make the symbols invisible, save it as an assembly and insert it into current design.
günther
