Selecting/Measuring the Center Point of a Circle/Arc
Hey guys -
What is the best way to select the center point of a circle in Fusion? I have a sketch concerning a number of concentric circles/arcs and I'm worried that one of my construction circles used to locate a hole pattern may have become slightly "off-concentric" from a nearby arc. Though I could go to town with Concentric constraints, I need to know if this has happened.
What I would have done in NX is go to Measure, click and hold down on one circle and select the "Center Point" from the menu that would have shown up (similar to the "Depth" menu that shows when you click and hold on a feature in Fusion360. Useful for one multiple things overlap and you're trying to select just one). I would have repeated this with the other arc, and seen if the distance was 0.000 or if they'd come slightly misaligned. Barring that, I would have gone to Point, selected "center point". I would have clicked both arcs, creating a center point of both, then measured the distance between to two to make sure it was perfectly zero.
Neither of these methods seems to work in Fusion360. I haven't figured out how to make a Point at the center of an arc, and when I click and hold down on a circle or arc, selecting its center point isn't an option. So what's the best way to do this in F360?
Thanks!
Intern, Pier 9 Lab, Summer 2015
