Selecting many fillet edges
kb9ydn
Advisor Advisor
kb9ydn
Hey all.  Is there an easier way in Fusion to select multiple fillet edges?  Imagine you want to fillet all of the inside corners of a maze but only the walls, not the floor or ceiling corners.  Selecting faces doesn't work because it creates fillets where you don't want.
C|
g-andresen
try „Rule fillet“ option
günther
wersy
Do you want it like this?
Then you can use "Selection Priority"
kb9ydn
Yes, that is exactly what I'm looking for!  Quite a clever solution!  I've never messed with the selection tools, but I will now.  Thanks!
C|
wersy
Me neither 🙂
@g-andresen  has pointed this out several times.
So if you have no more questions be so kind and mark it as solved, so that the topic can be closed.
