Selecting an Area between Two Bodies
I've been trying to select an area between two bodies on a sketch to extrude, but can't seem to find how to do it. Below I have included pictures of the bodies and sketch I am referring to. One of the isometrics is of what I have now and the second is a picture of what I want. The sketch shows what I want to be extruded. Thanks!
Replies (10)
etfrench
If you had attached your file to the thread, it would have been easier to show you.
However:
Start a new sketch on the top of the rings.
Project the ring body to the sketch.
Extend the ring segments to make full circles:
Select the area to be removed.
Use Extrude|Cut to remove it.
ETFrench
davebYYPCU
The four segments in the intended pic, should work for you,
because, the actual pic, shows the whole ring, it seems to me that the sketch has not been cut into segments, but if that were the case, then you could not show the intended pic, so there is something in that catch22 missing.
If you have projected the four outer rings to the Extrude sketch it should work as expected.
Might help....
When I extrude the sketch it extrudes the whole circle. Below is an image of what it looks like right before extrusion.
Here is an image right before extrusion
etfrench
Attach your file to the thread (Create the file from the file menu:  File|Export|Archive file *.f3d).
Have you tried the method I showed in my previous post?
ETFrench
Can you show me on the file? I'm not familiar with projecting. I just started using this software.
davebYYPCU
So that means the profile sketch you have does not contain the referenced crossing lines, that @etfrench mentioned.  You Extrude sketch needs those crossing lines in it.
project the two bodies, that will cut that sketch profile into three major bits, Extrude one, then either project the other two bodies into the sketch, or circular pattern the single web.
Might help....
etfrench
Here's a screencast showing the project technique:
Your model could be more efficiently done with fewer sketches and no moves (Moves should be avoided as much as possible. Use joints to position components).  Attached is one way to reduce the model to two sketches.  Use the arrows at the bottom left of the Fusion 360 window to walk through the creation of the model.
p.s. See Rule #1
p.s.p.s. Please show us a picture of the completed drone.
ETFrench
chrisplyler
Sheesh @etfrench that was a lot of work.
@matthewfriend99 all you need to do is:
1. Delete that last Extruded operation.
2. Edit that last Sketch.
3. In that sketch, you've already got one circle. Project in the others so that the one you've got will be divided in the right places.
4. End the Sketch.
5. Do the Extrude, selecting only those divided areas that you desire.
etfrench
What can I say, I like drones Smiley Happy  My screencast shows an easy way.  The file shows a better way.
ETFrench
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
