Seems to be using a previous selection - cache clear?
I have spent about 20 hours with Fusion 360. I have found it quite intuitive and after my non-experienced self got a handle on constraints, it has gone well.
However, in the last 10 hours or so I have had several times when the result of an operation is not correct for the selections made. Once it starts, it is persistent and crosses into other operations
. For example, the last time, I was trying to apply a sketch fillet and selected the two sides. Upon specifying the fillet radius, the result was a fillet from the first side to a place on a completely different line than selected. All the other fillets I attempted on the same sketch reacted unpredictably as well. Saving the project, closing and reloading it always returns the operation to normal. I can't share the project becaue it does not save the problem and the project is a patent application as well.
It's not a major hassle since I have a work around but it does seem to me to be a bug.
I see the "Clear user cache data" user menu item and perhaps if that worked, it would be a slightly faster work around but both probably require seeing the save complete in the data panel.
I apologize if this question has been asked before. Until I saved and reloaded and restored normal operation, I thought I was doing something wrong like accidentally pressing some keystroke command that changed the selection process. Now, it has happened too many times for that.
I could take a cropped video next time but I didn't think of it this time.
