Post Config for X-Carve
Does anyone have a post configuration script for the X-Carve by Inventables? Or if you have an X-Carve, which post config are you using?
philip.s
Hello @Anonymous,
What Autodesk product(s) are you using? Have you posted in the https://discuss.inventables.com/ forum yet?
Edit: Moved message to the Fusion 360 forums.
Hi, I'm using the Autodesk Fusion 360. Thanks!
Can you tel me what grbl settings and sender settings you are using? Do you have to change any settings in fusion 360? Thanks been try to get this to work for some time.
