Section View Question
Dear All
I know how to create a sectional view of a component. However, I'd like to be able to create and then print multiple sectional views. This is so that I can use the section view printouts as templates to help create a physical mould out of foam. Where there is more detail or complex curvature I'd need the sections to be closer together and where more plain they could be further apart. This is a similar process to lofting in traditional boat building.
Thanks in advance.
John
innovatenate
Autodesk Support
Autodesk Support
John
Welcome to the Fusion 360 community! There is a Beta available for Fusion 360 Documentation.
http://forums.autodesk.com/t5/Design-Differently/Want-design-drawings-Fusion-360-Documentation-beta-...
You may want to check out the Beta since the current version of Fusion 360 does not include drawings.
Fusion 360 Documentation Beta Forum:
http://forums.autodesk.com/t5/Fusion-360-Documentation-Beta/bd-p/3008
You may also want to check out 123D Make, which will automatically generate slices for you to make any model.
http://www.123dapp.com/make
Let me know if this helps or if you have further questions.
Nathan Chandler
Principal Specialist
Thanks very much for the quick response. Will look into your recommendations.
John
