Section View Alignment
bwalker145
bwalker145
Is there a way to maintain positioning of Section Views that aren't aligned with drawing X/Y?
Simple example below. If I create a section view between two holes, I can use the centers for the initial alignment. However, once I drag the end of the section view line to extend beyond of the edge of the part, the relationship to hole center is lost. This isn't an issue when the section view is aligned with X/Y on the drawing, as it will maintain the horizontal/vertical "constraint", but the relationship is lost when it's on an angle & is no longer properly aligned to the features.
jhackney1972
It all depends on your ability to hover to obtain the guideline.  The video will explain.
If this answers your question, please select the "Accept Solution" icon on my post.
John Hackney, Retired
