section analysis flickers
Message 1 of 11
After setting up a section analysis I get wild flickering objects.
Sometimes the inside is hollow, then it changes to solid. but for no apparent reason to me.
See it here:
http://autode.sk/1JmaByL
Is there anything I could do to get a better result?
Replies (10)
Message 2 of 11
Hmm, try going to Display settings (the little monitor on the bottom of the screen) then Visual Effects and be sure everything, except Anti-aliasing, is turned off, including Ambient Occlusion.  Also, if that doesn't help, try deleting your modified materials and returning them to the default.  I saw a problem similar to this before and that fixed it.
Jesse
Message 3 of 11
I tried everything you recommended. It did not help for my problem.
Message 4 of 11
colin.smith
Hi Leo,
There was a small update over the weekend that may have addressed this problem. Can you confirm that you have the latest version and if the problem is still there?
In the About window for Fusion you should see the release number 2.0.1593.
Colin
Colin Smith
Sr. Product Manager
SketchBook
Alias Create VR (aka Project Sugarhill)
Automotive & Conceptual Design Group
Message 5 of 11
Yes, I got the newest Version.
Sreenshot with different material and different appearance:
btw, I remember just now that I was affected by the "black modeling" that some intel Graphic Cards had. Maybe a graphic card issue?
Message 6 of 11
Hey Leo, if you could share the model I could try it out.  My email is jjurbanus5@yahoo.com
Jesse
Message 7 of 11
colin.smith
Hi Leo,
Please send me a copy of the file, I will have the graphics team take a look.
colin.smith@autodesk.com or post it here.
Colin
Colin Smith
Sr. Product Manager
SketchBook
Message 8 of 11
colin.smith
Hi @Anonymous
Can you send me your machine specs?
OS
Graphics
Memory
etc.
Colin Smith
Sr. Product Manager
SketchBook
Message 9 of 11
colin.smith
Hi @Anonymous
Looks like this is fixed in the next release.
Although I wasn't seeing the exact problem that you were I was getting strange results from section analysis also.
Here is what I was getting in the current release:
This is how it shows in the development build
This fix will be in our September release.
Colin
Colin Smith
Sr. Product Manager
SketchBook
Message 10 of 11
What your were getting looks very similar to what I have been seeing.
It looks like this will be solved with the next release. Very good. Thank you
Smiley Happy
Message 11 of 11
colin.smith
My pleasure. Please accept this post as a solution.
Colin
Colin Smith | Product Manager | Autodesk Canada Co.
M. 647-203-2590 | T. 905-582-7396
[cid:image001.png@01D03BCC.EFA6FD50]
Colin Smith
Sr. Product Manager
SketchBook
